Hi folks,
I'm just working up to changing my thermostat/coolant and I need to pop out and buy antifreeze. Everyone seems to just say "40% antifreeze, 60% water" are there different types that I should be looking out for?
Morat
Coolant: is all antifreeze born equal?
Morat
I use the red stuff, supposed to be 5 year protection even though its got no chance of staying in that long.
2 litres and I top the rest up with water.
If you want to flush the system out TFR does a great job
orangecurry
As far as composition goes, ethelyne glycol is what you are looking for.
Nitrates are (apparently) a bad thing.
BMW antifreeze says 1 part per 2 parts water for protection down to -20 C.
e30bmlover
- Ac Schnitzer prophet
i also use bmw coolant.
E30Mark
It's surprisingly cheap from the dealer!
not that they will be open today...
PM for details
PM for details
orangecurry
B81.22.9.407.454
1.5 lt = 6.80 without a discount - for a 'few pints of beer' cost, why not fit the real thing?
ajm-e30
i always use a 50/50 mix with the blue anti-freeze myself, dont forget that the cooling system on the m20 is 10.2 litres tho
Morat
thanks folks. I went with the red stuff from Halfords in the end. I'd have got the BMW stuff if I'd remembered I'd need some when I picked up my thermostat from the dealers.
bigkev
Toby_Unna
- Boost Junkie
because it's exactly the same as any other good quality (and cheaper) ethelyne glycol based stuff.orangecurry wrote:B81.22.9.407.454
