De-badged bonnet thoughts?
e30mclow
Post Wed Jan 10, 2007 4:16 pm
I'm getting a full respray in the coming weeks and I'm unsure weather or not to flush the bonnet, it looks nice in my opinion but there is no going back once the badge well is filled up. Has anyone pics of badge-less bonnets to help me decide???
NL-BMW
Post Wed Jan 10, 2007 6:05 pm
Looks good IMO
:thumb:
Sharabi
Post Thu Jan 11, 2007 8:38 am
Flush bonnets and boots can look ace, but please make sure that if you do it you get it done properly, as the last thing you want is filler cracking (i know from experience :( )
I have been told it should be Lead filled so as to prevent cracking as time goes on.
e30mclow
Post Thu Jan 11, 2007 8:50 am
Lead filled? Iv never heard of that being done. Is this what zoners have done? I would be interested in hearing how anybody on here has actually done it and what the results were like.. I recon I'll leave the BMW badge on the boot for the time being
mrLEE30
Post Thu Jan 11, 2007 11:23 am
i will second the above, i had a full respray on mine ans considered this too, but decided against it. lead filling is when they melt lead with a gas torch and literally wipe it into the hole unitl the hole is full of lead, then they file, grind and sand it flat and finish with a bit of body filler, it takes the correct lead (type H) and someone who knows what they are doing. if done well it looks great, if done bad you will need a new boot and bonnet.
in the end i went for Schnitzers badges instead
mrlee
e30mclow
Post Thu Jan 11, 2007 11:32 am
Would it not work to weld in a piece, tac on some mesh and then fill it over? Or is that just gonna end in crying? Thanks for the tips though,it sounds like a bit more work than I thought...
Royalratch
Post Thu Jan 11, 2007 11:41 am
It's not that big a deal. I had some lead fills done on some small rust holes (pinehead sized) on my roof.
Apparently the sunroff drainage channels get blocked some times and need to be blown out with air otherwise your roof bubbles and rusts.
The guy used lead even on that as hit's the proper way to do it.
Put it this way, put the badge on for now and you can always take it off and do it after - the reverse is more difficult.
Andyboy
Alpina Colada
Post Thu Jan 11, 2007 12:16 pm
Rusty roof?? Nice!
It's got nothing to do with sunroof drain holes - when they block water sits in the channels and finds its way into the car. When a roof rots through it's due to poor sealing between the roof skin and the sunroof housing. I've seen a number of E30's with the headlining out and severe ramapnt rust on the inside. I think Ian332iSport had a complete new roof skin put on his car. That's the only way to deal with rust - lead is no better than plastic filler as it will always drop out when the rust gets around it. Lead MIGHT last longer, but not much.
Lead is a thing of the past and presents more problems than plastic filler, particularly with the paint. For example lead doesn't like being coated in modern primers and baked in an oven. As for removing the BMW badge and filling the hole, that is pretty nasty IMO.
To do it properly you need to weld or braze a steel disc into the bonnet and you have to be careful to avoid distorting the panel. Then grind it back and apply a very thin skim of filler. If you just fill the reccess, it will ALWAYS crack.
Royalratch
Post Thu Jan 11, 2007 12:25 pm
There was no evidence of seroious rust, they took the lining out to check. It was neare the sunroof seal so maybe from that although I change that regularly.
I don't like the de-badge thing either.
Andyboy
Alpina Colada
Post Thu Jan 11, 2007 1:30 pm
Was the rust on the roof skin or the sunroof panel itself? Rusty sunroof panels are now very common - like mint original front wings it'd be worth scouring the breakers for good ones and keeping a few 'in stock'.
placey
Post Fri Jan 12, 2007 12:00 pm
at the end of the day do you have your name on your forehead? i've never figured mankind's need to label and badge everything. i'm in the process of de-badging and de-decalling the bike too.
i think de-badging looks good - on the right car though. get it wrong and it looks wrong.
my car was welded then lead loaded for the boot and bonnet over 2 years ago now - no problems so far and it can't be seen from any angle no matter what the light and how closely you look. dawsons did it for me - i went there because they know what they are doing. i would not trust this work to an average bodyshop - it requires someone with experience in this kind of modding.
hth - paul
i saw a doctor and she gave me some pills....
placey
Post Fri Jan 12, 2007 12:01 pm
that m3 looks excellent. de-locked and handled too. makes all the difference.
must be a worry having to leave the window down all the time to get in though....
paul
e36boy
Post Sun Jan 14, 2007 1:08 am
Mate if your gonna do it, Make sure its done properly, I bought a car once with some flushed bits and after a few weeks it became apparant that the guy had done it on the cheap. IMO i wouldnt, Im not a purist by all means but i think on a car such as an e30 you should only change things you can put back to standard easily, for selling on in the future purpose, Because people who are buying such cars are likely to want something they can put back to how it left the factory.
Davenotouring
Post Sun Jan 14, 2007 1:25 am
As Superintendant Chalmers said....
'What's the point in having a Honda if no-one knows it's a Honda.' After he got his badge stolen.
Maybe it would go if you are going for a 'bling'/euro look, if it's original, then no!!
BMW 328i Cab - Daily Slag
Bailey
Post Mon Jan 15, 2007 5:05 pm
Surly you could pick up a cheap bonnet from somewhere and get it sprayed at the same time as the rest of your car, but smooth the badge. I had my car resprayed last year, and i'm gonna buy a second hand boot lid before spring so that i can spray it to match my car, but loose the spoiler. that way, when i fancy putting the spoiler back on (or in your case some badges) its not too much trouble.
As for the lead filled argument, that would be the proper way. Lets face it in the long run, if it was done with filler it would crack and it would be a full bonnet respray.
Not too sure why it had to be type h lead though.
Regards Guy. :cool:
Andyboy
Alpina Colada
Post Tue Jan 16, 2007 1:25 pm
Bailey wrote:As for the lead filled argument, that would be the proper way. Lets face it in the long run, if it was done with filler it would crack and it would be a full bonnet respray.
Lead will crack too - it's just another filler at the end of the day. Plastic filler only cracks it it's been poorly applied and lead is well known for causing paint problems after a while - lead really is a thing of the past.
Bailey
Post Tue Jan 16, 2007 5:48 pm
What would cause the lead to crack? surly if you key the bonnet well enough for the lead to grab to it wouldnt would it? The only reason body filler cracks is because it shrinks isnt it? I'm only asking coz i'm thinking of doing my rear badge.
regards, guy.
BristolBulldog
Post Tue Jan 16, 2007 8:14 pm
Andyboy wrote:Rusty roof?? Nice!
There is a way around the roof issue. Using some cci's. its like menthol waxoil. I put some sponges in the roof of the car, and my dad did some of the other stuff. it puts a coating a few microns thick over the the whole of the roof inside, and seals it. this coupled with the lead filing kept my first e30 (m10 318) as new for 5 years with no re-currence.
the lead filling was used, as filling needed the roof to be bent in to be filled. the lead just stuck to the abbraided surface, so was fine.
Lead filing isnt as hard as it sounds.
I considered using this, along with braising when fitting my m3 rear wings. Instead i used a low amp welder, thinner weld, and more gas than usual. Lead filing has the benefit of not distorting a thin panel if done properly.
tbg
Post Tue Feb 06, 2007 8:02 pm
de badged bonnet u say! interesting! i bought my e30 cab last week, got it home and then realised that when it had been resprayed it had been debadged aswel! and i say it looks nice! but..........................i have just got hold of some black and white bmw badges insted of the ordinary blue and white checks!!! heres some pics of it .............. also i will post pics of my new badges fitted very soon!! tommy :)
zinderz
Post Fri Feb 09, 2007 5:51 pm
looks nice
Tech 1.. Old School Cool
spence_star
Post Fri Feb 09, 2007 5:56 pm
Dont flush them, why dont you want people in front of you or behind you know that a Beema is up your ass or has just left you.
Its all about the badge but thats in my opinion.
Returned after many years out.
dom-1984-320i
Post Fri Feb 09, 2007 6:05 pm
If not done properly you might be running the risk of looking a bit tacky IMO. Last thing you want is for cracks to show after time so if you go ahead and debadge you car please do it right. Personally i think keep the badge's but thats just my opinion mate.
snooka
Post Sun Feb 11, 2007 12:13 am
lose it!!! it gives everythin a smoother look, people will still recongnise you drive a BMW :P bu they won't be able to steal (scratch ur hood) the sign
itsky12
Post Sun Feb 11, 2007 12:33 am
it's not a bmw with out u showing it off so everbody can see it
