320i/325i inlet manifolds...
bimmaman
Post Tue Jan 09, 2007 6:43 pm
What's the difference? Apart from the slight difference in appearance?
As some of you may know, my mate is selling his, and the eagle eyed among you have pointed out he MAY have a 320i inlet manifold fitted on his 325i sport...
http://www.e30zone.net/modules.php?name ... 119#566119
If this is so, will it be detremental to the performance? It goes like a 325i should, so I don't see what the problem is... :?
zaust
Zone day release
Post Tue Jan 09, 2007 8:23 pm
diameter's inside.
M30 Tech 1 Touring on gas.
Cloggy Saint
Post Tue Jan 09, 2007 8:25 pm
bimmaman wrote:What's the difference? Apart from the slight difference in appearance?
There's no MAY about it mate, that's definitely a 2.0 inlet manifold. The inlet hole on the 2.5 manifold is obviously quite a bit bigger to accomodate the larger throttle body.
Simon
Post Tue Jan 09, 2007 9:00 pm
Thank you, definitely not a MAY. :mad:
bimmaman
Post Tue Jan 09, 2007 11:26 pm
OK then... so supposing it IS a 320i manifold :wink:, Why would the previous owner put it on? Will there be any fundamental side effects from this (lack of power / poor running etc)?
I only ask, because AFAIK this car has no such problems... (And I'm quite interested :D)
