My bad luck has got to end!
DemonDaz
Post Fri Apr 01, 2005 4:15 pm
OK, so after deciding to do my brakes last weekend, I bought a 7mm Hex key, jacked up the front of the car, using scissor jack to get it high enough for the trolley jack to go under, then using trolley jack and then an axle stand for good measure (I only jacked up one side at a time).
I managed to swing the calliper up to change pads, but could not remove the bolt holding the carrier on, Welded up good and proper, it ended with my breaking the adapter for my torque wrench, giving up and putting it back together.
I then jacked it up to take it off the axle stand and just as I was pulling out the stand, BBBBAAANNNNGGGGGG!!!!!! The trolley jack gave way :eek: :cry:
Fortunately I had my hand on the side of the Axle stand not the top, so my hand was saved, Boxers were a bit squidgy though! :eek:
Anyway it went into the garage, I had the front discs and pads, a cambelt, tensioner and water pump, the garage fitted the lot, and changed the rear discs and pads, front shocks as you could turn them upside down and they just slid in! Total bill Ԛ£780
Oh and the springs the last person used to lower the car were cut with an angle grinder 8O , no wonder the shocks were shot!
I thought that was not too bad considering.
All I need to do now is fit the front spoiler.
Steve
Post Sat Apr 02, 2005 8:28 pm
You must have rebuilt that car by now m8.
makes u wonder what other things your gonna find :cry:
webmaster@e30zone.net
billgatese30
Post Sat Apr 02, 2005 9:21 pm
Steve wrote:makes u wonder what other things your gonna find :cry:
fingers 8O 8O 8O 8O
at least by the sounds of things....if not whole limbs :lol:
