what diff ratio should i go to
gazza
Post Sun Jan 07, 2007 8:37 pm
318 m40 cab manual currently on a 4.10 diff acceleration is ok and tops out around the 120mph mark(well thats whats on the speedo) bad point keeps returning 22-23 mpg (all motorway/dual carriageway) but hey why sit at 70 when i can go a bit faster (most of the time) i have a large case 3.64/3.65 cant remember exactly which one .....anyone out there running a 3.64/5 diff on a 1.8 power house is it worth the change i commute in the car daily to work 50 mile round trip
how much would i loose of the line in acceleration
what sort of top end would i get on the motorway (in germany honest)
how much better would my consuption improve (without loosing my leadfoot)
last question i have fixed the pipe that runs from the fuel tank to the cannister on the ns wing (parts of it were missing) i see it goes on to a wire leaving the cannister and into the engine somewhere(if the pipe was missing would the cannister be sucking air and assist in the some form of bad running)ie instead of sucking petrol vapour but air wouild it have any effect
many thanks
Post Sun Jan 07, 2007 9:15 pm
3.91 diffs are ok on 1800's (ive had 2) but I wouldnt know about anything else.
Dont know about the bad running, but the pipework from the throttle to the canister valve is the important part.
snoops
Major Helmet
Post Sun Jan 07, 2007 9:26 pm
id say 3.64 is alright as youd get better economy but you might lose a bit off acceleration
fuzzy
He who sleeps with "Gingers"
Post Sun Jan 07, 2007 9:36 pm
i have a 3.91 lsd on mine and that seems to run out of steam at about 135-140 but it doesnt half get there fast winkeye .must be down to the diff gearing because ive had far more out of the same engine when fitted to a toyota with a supra lsd.i dont ever concider fuel economy 8O
Post Sun Jan 07, 2007 11:47 pm
snoops wrote:id say 3.64 is alright as youd get better economy but you might lose a bit off acceleration
Too low for a 318 cab. It would seriously affect 1st gear, and it would work too hard in 5th, so I don't think you'd see any economy increase either.
