The rightside of the dash doesn't light up also the main light switch area.
Simple process to change the bulb?.
Dash light
You mean dash or instrument cluster?
Light switch area is pretty easy, you need to drop the main under column cover down, remove the under clocks piece then remove the light switch panel, its held in by two 8mm or 10mm hex nuts, most of the time ive undone these by finger.
mrLEE30
to change the bulb in the cluster you need to remove the instrument cluster, there are two light bulbs (left and right) remove the cluster, change the bulb.
to remove the cluster best is to remove the steering wheel (can be done without) look up under the instrument dash cover and you will see two small screws, remove and the upper instrument cluster surround will come off. remove the trim above the steering column by finding the two retaining nuts accessed from behind and underneath (you need to remove the same cover under the steering column mentioned by dan).
you wil then see the four screws (two(3?) above the steering column, two up under at the top) that hold the instrument cluster in, remove and pull the cluster out (top first normally works best, note the connections behind before you pull it all the way off!! you should be able to change the bulb without removeing the cluster completely, it is held with a bulb holder that sticks out, turn and remove it, replace the bulb and refit.
10 min job, (25 min the first time you try)
clever dicks
like me with small hands can change these without removing the cluster but you haver to know where they are first
clever dicks
mrLEE30
even better description and you can see the bulb holders in the later pics...i THINK the big one adjacent to the blue connector is the oun you need to change, but you will figure it out once the cluster is removed!!
http://home.comcast.net/~cdeegan9/dashb ... ard_1.html
mrlee
mrlee
mark_i
isn't that one of those Spoonerisms where the words get swapped around?clever dicks like me with small hands
jcjdavis1
Hi might be a good idea to swap them all when the dash is out,sods law dictates that when you put it back together another bulb will blow shortly.
gazm3
Thanks Gents.
The left side of the dash is ok.
Its the right side and the light switch area.
Could this be a fuse?.
Not a fuse, stop trying to work your way out of it
gazm3
Which is the Rev/ Temp bulb?.
Closest to the blue connector?.
Tighten the two small brass nuts on the back while it's out.
gazm3
Thanks Brian,
Im trying not to take it out, but my hands are to big!.
Its fiddly as f0ck.
Its fiddly as f0ck.
