has anyone put after market remote locking in to their motor?
which wires(colors) do i need to conect to the reciever unit
remote locking
stitch-626
wanted passenger side rear door for touring.pref dark blue
wanted, toy Bmw's any series, not for me for my 3year old daughter.
I have a rondevous with death, i drive an E30 in scotland
smithy318i
I don't mean to patronize, but there is a search function on this site.
anyway... this is what your looking for.
Brianmoooore wrote:The place to fit a module is above the glovebox. The central locking wires you need go across the glovebox heading for the passenger door socket behind the footwell speaker.
The wires you need are : yellow/blue - earth momentarily to lock; and green/blue - earth momentarily to unlock.
If the module flashes the indicators as well, then these are blue/red and blue/black, both on a large multipin plug and socket at the back left of the glovebox.
stitch-626
cheer mate i'll pass the search comment on to the wife.
cheers should be able to sort out the locking
mummy-boo
i wish he wouldn't blame his stupidity on me. i told him to check before posting.
Hayley xx
"Float like a Cadillac, Sting like a BEEMER!"
Gortour
I believe Deadlocks are the problem working remotely, as this is mechanical...
Unless someone knows how to get around this... Never yet known a remote E30 with working deadlocks...
There's no great technical problem in engaging the deadlocks, especially if you use a two channel remote control, but the driver's door doesn't have an electric deadlock to operate.
Gortour
Could say, a passenger deadlocker be used on the drivers side, or does the driver's deadlock actually carry the 'deadlock the rest' signal?Brianmoooore wrote:There's no great technical problem in engaging the deadlocks, especially if you use a two channel remote control, but the driver's door doesn't have an electric deadlock to operate.
Was thinking along those lines myself as I wrote the last reply.gortour wrote: Could say, a passenger deadlocker be used on the drivers side, or does the driver's deadlock actually carry the 'deadlock the rest' signal?
Can't see any reason why the driver's door locking arrangements couldn't be made the same as the passenger side.
You would lose the manual deadlock capability, but would gain the electric deadlock.
It would be probably best to disconnect the deadlock motors from the locking ECU and work them by a seperate impulse relay from the remote receiver.
