Convertible rear speakers.
gazm3
Fri Apr 01, 2005 12:06 am
Im interested in some new rear speakers on the Msport.
Convertible owners seem to be some what limited, with the size of the stupid holes, I mean only big enough for 13cm or 5 1/4" flush mounted speakers, its pants. :cry:
As for those stupid clipped covers, they are very s*it. Those silly metal brackets that break (easy).
Have any of you chaps had this most anti-social problem. And more to the point how have you tackled this problem tastefully.
What are the best 13cm speakers?.
Cheers Gareth
Geeman
Fri Apr 01, 2005 12:23 am
Try these dude... supposed to be amazing.
Bluespot Audio (Blaupunkt)
Or even these
Blaupunkt again, but all built in
Giles.
bootyman
Fri Apr 01, 2005 8:28 am
or you could stick some mids in your front door cards. I done this with some Blaupunkt speakers and it was nice.
nav786
Fri Apr 01, 2005 3:07 pm
i knw what ur sayn mate. i have same problems. and the clips are fooking annoyin :cry:
Gromit
Fri Apr 01, 2005 10:42 pm
I've been doing some research on replacement speakers with a sensible price-quality-ratio. This is the setup my convertible will be getting in the near future:
Rear:
http://www.dls.se/english/speakers/425.htm
Front:
http://www.dls.se/english/speakers/ms5.htm
Geeman
Fri Apr 01, 2005 11:04 pm
And both sets fit in the OE speaker positions without any modifications...?
gazm3
Sat Apr 02, 2005 5:22 pm
Giles, those Blaupunkt speakers look good.
I think I just want to update in the space's Iv'e got, with the best possible
speakers rather than creating new holes in door cards for speakers/tweeters. Those wing mirror tweeter, OEM part thingy's look ideal.
Whats the quality of the speaker cable in these cars?. Any good or 15 year old tat?.
Gareth.
Geeman
Sat Apr 02, 2005 6:19 pm
You might as well replace the cables, it'll only be a hlf hour job (if you know what you're doing). It's only crappy bog-standard cheapo speaker wire that's in them, and if you're spending the money on decent speakers and already have a good head unit, you might as well go the whole hog and do it properly, it'd be rude not to. Knowing you, if you don't do it, it'll always be in the back of your head that you didn't do it, when you could have... :wink:
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Sun Apr 03, 2005 9:50 pm
what's the procedure for changing the cables?
I'm about to install a new component set ( just cheap ones )
fowler
Boost Junkie
Mon Apr 04, 2005 7:18 am
Directed electronics also do a very good set for the rears as they are 5 1/4 but the mounting depth is about 42mm i think
will give a link as soon i can find them on the net saw them at my mate's shop any sounds give me a shout i can usaully get a bit cheaper than RRP
Regards Ben
