I am trying to figure why my car takes so bloody long to start -
having a cup of tea and have come up with a theory:
if fuel was coming in past the fpr then in to rail then back to the tank would it start and run at all?
i know its a 2 second test to see if mine are backwards but its late and dark and i'm done spannering for the day.
i know fuel should go into rail then gets backed up by the fpr which then releases whatever is over the 3 bar back to the tank
it is very unlikely my theory is right but hey at least its an idea....
you see i figure its taking so long to statr as theres so little vacuum when the engine isnt running its hard to get fuel through? when it does splutter into life it runs okish (apart from 1000-1400 constant low speeds with little or no acceleration, again as a result of the low vacuum) - the cacuum of the car runnnig allows the fuel to go through into the rail and tne back to the tank
the more i write this the less plausible and the more like totasl rubbish it sounds
oh well
could just a plain and simple faulty fpr cause this long statring and or juddering problem?
quick Q - will a car run at all with fuel lines on backwards
ian332isport
Total rubbish I'm afraid
Vacuum has nothing to do with the injection of the fuel (apart from a small change in fuel pressure due to the vacuum connection to the FPR).
I don't believe the car would run at all if the pipes were the wrong way around. If you have a problem where it cranks for ages before starting, then it could be either a leaky FPR that is not holding pressure in the fuel rail, or possibly a similar problem with one or more of the injectors.
Either way, you need to get a pressure gauge in there to see what's happening.
Ian.
Ian.
I see what you're getting at, but I'm sure there would be no fuel drawn in by this.
Jon_Bmw
- Dangerous when thinking
Liam, very quick test, take the two hoses off. Put them in two different containers. Go crank the engine up and see which container gets filled. Job solved(or more likely one potential problem written off)
BMW_YARD
Long cranking until starting could be a faulty non return valve on the feed side of the pump, but this shouldn't cause problems after it is running, as Ian said get a guage on the pressure line to the fuel rail.
You can check residual FPR leakage by running the return line from the fpr into a large container, after engine switch off, there should after a short period of time be no fuel being returned to the tank, i.e. FPR is holding rail pressure.
This would be a good test if you don't have a pressure guage.
A new fuel filter has made a noticeable difference to the starting time on my car; they're supposed to be done every 4 years/40,000 miles - mine hadn't been changed for 6 years!
liam012
bmw yard thats a good test allright will try that
now dont laugh but my gauge shown here:
http://www.tooled-up.com/Artwork/ProdZoom/59075.jpg
showed the same reading at the rail and directly out of the pump - unfortunately the reading is of no use to me as it is depending on how you read the gauge either: "good" or "20 ins HG" or "2.8" psi or "vacuum 0.7" or fuel pump pressure 0.18bar/2.8psi"
i asked the guy for something that would do for a fuel pump gauge but i am worried this is horse.....
on another note when clamping the fpr return pipe with a pliers the revs rise from 900 (which is correct) to 1000? is this correct i also notice if hotwiring the pump and clamoping the return line the sound of the returning fuel dissappears (obviously) but when i release the pliers it takes about 2 1/2 seconds for the sound of the return line to start again?
any more thoughts
any more thoughts
