Oh joy! Wrong bloody tank!!!! with a hole in it...
johnna
E30Zone Irregular
Post Thu Jan 04, 2007 9:37 pm
It seems to be the tank filler neck, in the classic next to the tank position... BOOOOO!
Thankfully a local scrappy has (well had three months ago) a nearly new one for £20. I have a cabby and the tank is a touring item. It will still fit won't it? Just a bit bigger.
Can I get the tank off by only splitting the prop in the middle? Last time out when looking to replace the centre bearing, I could not loosen the prop to diff bolts.
Also, I have some frost's tank repair stuff:
http://www.frost.co.uk/item_Detail.asp? ... ,%20946ml)
I bought it for my capri... reckon it will work on the e30 filler neck problem?
kevin316i
Post Fri Jan 05, 2007 1:04 am
Do you not need to remove the fuel tank to use the Frost stuff? If so, you'd be better off getting a replacement tank.
johnna
E30Zone Irregular
Post Fri Jan 05, 2007 10:09 am
Yes, but it would be cheaper, alas having read the notes, it takes 96 hours to go off :cry:
New tank for me!
BMW_YARD
Post Fri Jan 05, 2007 10:50 am
What tank do you need as I've got a mint one here.
Post Fri Jan 05, 2007 11:08 am
Prop has to come off to remove tank
slinky
Post Fri Jan 05, 2007 11:20 am
Prop shaft and exhaust off. If you're having difficulty with the prop shaft nuts as a cheater bar/extension on your spanner or ratchet works. I had to take my prop shaft out and the nuts were very tight. But with the cheater bar and a bit of swearing they came off, don't forget to leave the car in gear as well! Sorry if I'm telling you things you already know!
While you've got the tank out if your metal brake lines need replacing it would be a good time to do them as it's a lot easier with the tank removed! winkeye
johnna
E30Zone Irregular
Post Fri Jan 05, 2007 12:22 pm
I have the tank... the little copper pipe from bank to bank is twisted and ruined (easy mend with plumbing compression joints though)
Aye the prop to diff bolts were attacked with the car in gear and with a meter long breaker bar. I'm a big strong old MoFo so it's a surprise they didn't give.
johnna
E30Zone Irregular
Post Fri Jan 05, 2007 6:09 pm
Wrong fecking tank!!!!
I said to him, that looks like a 4 cyl tank, no he was insistent... GGRRRRRRR! So I have wasted an hour or two repairing the 4 cylinder tank...
So mine is the 6 cylinder type with pump on driver's side (with warning light sender?) and the level sender on the other side. Or at least that is what I can summise...
Can I use the 4 cyl and adjust the wiring to get the fuel gauge to work? eg short the wires on the driver's side? or similar.
The breaker's have several 320's in as well, but I doubt the other tanks are as clean as this.
Post Fri Jan 05, 2007 8:15 pm
What engine is in your car johnna? i'm getting lost!
Morat
Post Fri Jan 05, 2007 8:45 pm
I thought it was saloon tank vs touring tank?
and old style twin senders vs newer style single sender....
Post Fri Jan 05, 2007 9:58 pm
If you are changing from one level sender to two or the other way around you will also have to change the gauge in the clocks.
johnna
E30Zone Irregular
Post Fri Jan 05, 2007 10:04 pm
Sorry for the confusion!
I have a 320i cabriolet. 1990 motronic.
I used to have a 316i two door.
The 320i tank has two deep banks with a sender on either side.
The 316i had a deep driver's side, with a pump and sender on that side only.
The tank I have got from the breaker's is just like the 316i unit I had.
Now from the same breakers, I got a 320i touring propshaft, and he told me "we have a nearly new tak from that too". It is that nearly new tank I have bought now.
But this is the question... I presume the passenger side sender unit is no more than a variable resistor, so can I just link the wires?
The passenger side sender has only two terminals,
The driver side sender has three terminals, as per later motronic system.
Post Fri Jan 05, 2007 10:09 pm
No, no matter how many different ways you wire it it wont work properly, the only way is to swap the gauge, I speak from experiance :wink:
johnna
E30Zone Irregular
Post Fri Jan 05, 2007 10:52 pm
b u g g e r :x
I was hoping to fit a resistor to at least activate the gauge, watch my mileage carefully and then obey the warning light!
I am very temped to cut an aperture in the passenger side of the new tank and using a rigid alloy collar inside the tank, bolt up a sealed joint.- Six or eight bolts in a circular pattern to sandwich the tank sheet steel between two alloy faces (collar within the tank, sender unit top mount outside the tank).
Would the tank be deep enough? I can make it work! :mad:
As for the Saloon Vs Touring tank differences... so far etk indicates 4cyl Vs 6cyl. :!:
smithy318i
Post Fri Jan 05, 2007 11:50 pm
You will be able to bypass the passenger side sender unit by shorting the two connections together.
this will leave the single sender which is attached to the fuel pump.
you will also need to replace the fuel guage in your cluster for a one which is designed for a single unit.
I have the opposite problem, in that i have a 2 sender 63L? tank and a fuel guage for a single.
if you want to swap your fuel guage for mine and mine for yours, let me know.
johnna
E30Zone Irregular
Post Sat Jan 06, 2007 12:04 am
Can do! Either that or swap tanks...
Hmmm... which is easier???
Post Sat Jan 06, 2007 12:06 am
Are you going to cut the tank with a grinder? winkeye
(wheres the fire smiley when you need one)
johnna
E30Zone Irregular
Post Sat Jan 06, 2007 12:11 am
If I do that...
I shall be cutting the old tank which has been sat with water in it, plus I shall be cutting slowly
Plus... I have welded fuel tanks before with no problems!!!
As long as they are all metal (ie no thermo plastic), stuff the buggers with rags and set on fire.
This purges all of the remaining petrol vapour. :cool:
Oh the cleansing power of flame!
I even stuck one on a Barbecue once. 8O
smithy318i
johnna wrote:Can do! Either that or swap tanks...
its a lot easier to swap the guages. All you need is a small screwdriver.
johnna
E30Zone Irregular
Post Sat Jan 06, 2007 12:19 am
Okie dokie!
We'll do it Sat PM or on Sunday, if that is okay.
Can I get the clocks out without stripping the steering column covers?
I'd rather not touch them.
I've done it with many cars that said the wheel and shrouds had to come off.
Post Sat Jan 06, 2007 12:26 am
Cluster comes out without touching the shrouds or the steering wheel. Just remove the trim panel immediately below the cluster, by reaching up behind it and unscrewing two round nuts by hand, then basically unscrew every screw you can see. (Eight in total).
johnna
E30Zone Irregular
Post Sat Jan 06, 2007 12:40 am
I thank you!
Typical, them that know very little tag on the end of a thread for some reflected glory...
Tee hee! Just teasing!
Still got to swap that bloody tank though! BOOOOOOOOOOO!
smithy318i
Post Sat Jan 06, 2007 12:47 am
saturday afternoon or sunday is fine. Not sure what brand of cluster i have? Not sure if they are different or not!
Brian. Are moto and VDO fuel guages the same ?
Post Sat Jan 06, 2007 1:16 am
AFAIK, all the bits are interchangeable.
johnna
E30Zone Irregular
Post Sat Jan 06, 2007 12:08 pm
Just wait smithy,
my new tank has a bastard hole in it!!!! :x :x
Arrrggghhhh!!!!!
Bugger.
I'll have to see what else they have.
smithy318i
Post Sat Jan 06, 2007 6:06 pm
johnna wrote:Just wait smithy,
Arrrggghhhh!!!!!
Bugger.
Ignore my SMS then.
