gear box and diff
anisotropy
Post Thu Jan 04, 2007 1:21 pm
Can you recommend me oils for gearbox and diff (open) for my 318is
Kevin
Templ8e30
Post Thu Jan 04, 2007 5:08 pm
SAE 90w for the diff, SAE 80w for the gearbox unless it needs ATF (there should be an I.D plate saying so if it needs ATF).
Any well known brand is good enough.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
ajm-e30
Post Thu Jan 04, 2007 9:47 pm
i run semi-synthetic engine oil in my gearbox and diff, have done this for a while and never had any problems
anisotropy
Post Fri Jan 05, 2007 12:40 am
k
