audiophile question - soundstaging e30 - tweeter placements
anton
Post Thu Jan 04, 2007 9:27 am
Hi guys, ive had my e30 325i 4dr now for 4months, so this holiday im busy installing an audiophile quality sound setup, i ve been taking part in iasca competitions for some time now.. since 2000, my other vehicle, a pickup placed 3rd in the iasca national championship in 2005.
the equipment im fitting to the e30 are as follows:
nakamichi cd 400 source unit
mid woofers from kef coda 7 home-hifi bookshelf speakers
dls t25 reference series tweeters (www.dls.se)
jl audio 300/4 amplifier
my subwoofer is a decware 10" dhm108b (10" handmade woofer with 18inch motor assembly)
in most vehicles i've done.. like my pickup, which scored 46 out of a possible 50 for imaging i had the woofer and the tweeter in the kickpanel locations.
before i ripped everything out of the e30 i did a test,at that stage i had the woofers in the standard factory location. it seems if i put the tweeters down below that the stage height isnt high at all..
the only way i could get decent stage height was to put the tweeters by the triangular panels nexto the side view mirrors.
any advice from anyone that've played with the tweeter positioning?
another thing, i was after more low frequency extension than anything else, so i made my enclosure 1.46cu ft
i've cut out a 280 x 280 mm square out of the rear shelf.
the enclosure i made bolts onto the rear shelf from underneath..
and fires into the cabin..
any feedback or tips would be appreciated.
regards
Anton
cape town,south africa
ed325i
Post Thu Jan 04, 2007 2:01 pm
Mahmood
Post Thu Jan 04, 2007 2:49 pm
This is one for dark sounds (Ali)...
anton
Post Thu Jan 04, 2007 3:35 pm
hi there,
thanks for the link.
the problem there is.. the seperation between the tweeter and mid woofer. there will be time alignment issues.
the tweeter and midwoofer need to be as close to each other as possible. not further than say 20- 25" apart..
like in a home hifh speaker... uk's blokes will known the brand celestion or mission etc..
do they ever make cabinets where the tweeters are way apart from the woofers.. not really.. well the same applies to the car.. the thing with the e30 is that one cant seem to put the tweeters on the kickpanels like some other vehicles.
i think its the materials they use for the dash.. it blocks high frequency.. because when one does this... the soundstage height is like gearlever level.. it should be like mid windscreen..
having the tweeters in the panels next the side view mirrors is ok.. except for the fact that the driver is very very close to the one tweeter on one side.. this throws imaging of somewhat..
the idea of kickpanels is basically so that the difference between DRIVER vs. left speakers AND driver vs right speakers is kept less. sound travels at a certain speed. you want all your speakers to "ARRIVE" at the same time..
else certain frequency bands sound "seperate".
cheers
Anton
someone want to forward this to "dark sounds (ali)?
kam325itouring
Post Thu Jan 04, 2007 3:56 pm
hi ive done builds in the kickpanels to house my focal polyglass components.... they are 13cm and te tweeters are built into the panel too. To be honest i was very impressed with the sound comming through. i will try to get pics they were on here on a thread before.
kam
anton
Post Thu Jan 04, 2007 7:53 pm
kam, hi there
ok do me a favour, here's a test to check your sound stage height.
put in a very good recording, something of audiophile quality..good quality jazz cd's work well for evaluating..
some other ideas, dire straits are good too for this purpose.
turn the volume to a normal listening level.
close your eyes.
now lift your right hand... and follow the voice,, i.e the vocals are generally centre... try and "Grab" the voice asif snatching it out of the air.. if you know what i mean.. now open your eyes without moving your hand..
this is your sound stage height.
if in doubt... tilt your head to the side sothat the headunit/source unit is at the same level as your eyes...
do the same test... the little bit of testing ive done showed up a sound stage height of more or less hedunit level..
it needs to be above the dash... as high as possible..
check it out.. tell me .. would be interesting...
thanks so far.
cheers
Anton
Cape town,south africa
kam325itouring
Post Thu Jan 04, 2007 8:32 pm
yo anton
sound staging in a e30 is quite difficult because the speakers are so far in the kick panels!! but i got mine as best as i could i was gonna say come over and have a listen, but it would be a bit of a trek for you!!! lol. i got it about shoulder height i got quite a few orchestral tracks that i use when testing system that i have installed(i have my own car audio business)
Because i have angled the mids on mine, the main prob you got, well on my car first is the is the glove box comming down, i had to cut my glove a bit but you cannot se it........second on the drivers side is the gas pedal you cant angle the speaker too much i done it enough so you can still drive comfortably!! :D
hope this is of some help kam
kam325itouring
Post Thu Jan 04, 2007 9:27 pm
anton i found the link to my install here it is.....
