Necessary to seal tops of front wings?
kevin316i
Post Thu Jan 04, 2007 1:04 am
Is there a functional reason for the bead of sealant at the top of the front wings, just below the A-pillars, or is it just aesthetic? I'm taking the wings off for some waxing underneath and am wondering if I need to re-seal at the top.
Thanks,
Kevin
316eyes
Post Thu Jan 04, 2007 1:48 am
If BMW put it there - replace it. Probably stops ingress of water to a joint or seam which will be bad new in the future!
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
kevin316i
Post Fri Jan 05, 2007 1:01 am
My previous E30 had its front wings replaced at some stage in its life and neither were sealed at the top and I never saw any issue with this. It means some water running down the side of the body but water will tend to get in there anyway. I have some Sikaflex somewhere in the garage so theres no problem in doing it but it just delays getting the car ready for Monday.
Martinaston
Post Fri Jan 05, 2007 11:31 am
I would imagine the wind would force even more water in there and as you don't normaly paint the wings before they go on it would rust that bit quicker.
There is NO nucleus.
