Mystery spout
braincat
Post Tue Jan 02, 2007 6:37 pm
Just left of the rocker cover, in the bulkhead, is a little rubber/plastic spout which points down at the floor. Does anyone know what its for? I've just knocked mine off whilst tightening a nut on the rocker cover, and it won't clip back on as the angle's awkward. I must admit, its so subtle that I'd never even noticed it until I knocked it off. It must channel water as there's some gunk inside and the tiniest bit of rust on the surrounding metal.
buster
Post Tue Jan 02, 2007 6:41 pm
its for drainage of the scuttle area.Sometimes called the elephants trunk.It'll probably be bunged up with crap.Clean it out and re fit it by pushing it flat against the hole and twist it from a 90 degrees position ( 3 o'clock or 9,cant remember) to down over position and it'll stay on if located properly.
If you cant still get it on try warming it slightly on a radiator in the house so it sofens up a bit.Could try a small amount of wd40 on it also as they tend to go hard with age.
braincat
Post Tue Jan 02, 2007 6:43 pm
Cheers fella, you learn something new every day.
buster
Post Tue Jan 02, 2007 6:45 pm
No probs,make sure you fit it though,dont just leave it off !
