Leaky Boot
Post Mon Jan 01, 2007 10:54 pm
Hi
When it rains i get a puddle of water in the right compartment of the boot and i have discovered that its a faulty seal so ive tryed tightening the boot catch but it still leaks does anyone know how to fix this without needing to replace the seal.
gareth
Post Mon Jan 01, 2007 10:57 pm
are you sure it's not the rear light seal?
Post Mon Jan 01, 2007 11:07 pm
Not to sure as it looks like one of the previous owners has siloconed it up so not to sure, but i no the boot seal is definatly leaking
Cava
Post Mon Jan 01, 2007 11:42 pm
You can use grease (like Castrol LM) on the seal to get it more flexible for a better fit to the boot lid. Also check under the boot seal to make sure that their is no rust starting (which could also let water in). The rear light seals are cheap to replace so these are also worth a second check.
Post Tue Jan 02, 2007 12:24 pm
THANKS I WILL TRY THAT
Post Tue Jan 02, 2007 1:37 pm
Water in RH boot well: Rear light seals, drain channel for boot lid (Rust hole under the rubber seal), rust hole on the inner wheel arch where the fixing bracket for the fuel filler tube is, rust hole on the outer part of the inner wheel arch, near the lip arch, disconnected sunroof drain, fixing clips for the "shark fin" trim pieces behind the side windows/doors.
