2.7 crank
midnight
Post Fri Dec 29, 2006 6:15 pm
can u use a 2.7 crank in a 325 turbo, if so what are the benefits of useing the 2.7 crank over the standard 325 crank
maxfield
Post Fri Dec 29, 2006 11:06 pm
more displacement which means more power and torque
mac325i
Post Sat Dec 30, 2006 1:31 am
I think (feel free to jump in anyone) a 2.7 crank will create low compression, if used with 320 conrods in a standard 325 block.
Haven't a clue on C/R though
midnight
Post Tue Jan 02, 2007 10:43 pm
so u know how much it mite lower the compression?
Turbo-Brown
Boost Junkie
Post Wed Jan 03, 2007 5:50 pm
Don't be too hasty to assume that lower compression is such a great thing.
If it lowers the CR by just dropping the pistons down the bores, you might still end up with an engine that's as prone to pinging as one with a higher CR.
Keep an eye on the squish band is what I'm saying I guess.
midnight
Post Fri Jan 05, 2007 6:56 pm
no what i wan thinkin was using the 2.7 crank, getting h section steel rods and forged pistons aswell
Turbo-Brown
Boost Junkie
Post Fri Jan 05, 2007 7:13 pm
Interesting, and strong sounding :D
Where you getting the rods and pistons out of interest?
Always thought it'd be interesting to see if anything like the rods from a yank V8 would swap straight into an M20 as their massive tuning industry seems to mean you can get a set of 8 steel rods for £400! Four of us get together and that's £300 for an engine set each.......bit of a pipe dream though unless anyone's got the particulars of any American rods?
Ant
Retired Team Member
Retired Team Member
Post Sat Jan 06, 2007 10:01 am
Hmm, nothig from a chevy V8 (SB)would work Alex, the rods are thin in section ( 2 per journal) haven't seen inside any big blocks yet though :wink:
Turbo-Brown
Boost Junkie
Post Sat Jan 06, 2007 11:14 am
Aah, that's a shame.
Ho well, nice idea while it lasted :)
WillG
Post Sat Jan 06, 2007 12:59 pm
people have used air cooled VW wiseco forged pistons in BMW engines before with slight mods if you can machine stuff then thats some very cheap forged pistons, best you can do with rods for cheap is use the m50 ones if you put them up side by side with the m20 ones they look alot stronger there is a picture on the ticco website
Turbo-Brown
Boost Junkie
Post Sat Jan 06, 2007 1:01 pm
Now that IS interesting!
Got any details Will? :D
midnight
Post Sun Jan 07, 2007 9:35 pm
hmmm.... where i found steel rods for the m20 was from a company in america called ireland engineering, they have thier own website, they sell quite a lot of good stuff for beemers, allthough it is pure long buying stuff from america, i got stung paying £75 import tax when i got my manifold sent over from america.
