325..cut out while driving
eltel
Post Wed Dec 27, 2006 3:59 pm
hi there...got a 1988 325i...fast and smooth no real probs...but over the last 3 months whilst driving at varying speeds..(40, 50 70mph). the engine has just cut out for about a second...the power stops, the needles drop but then when you realise whats happened it all resets itself and off to go again..it's like the ignition is cut or something...
any help appreciated!!!
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
Post Wed Dec 27, 2006 7:30 pm
Change the main ECU (DME) relay for a start. White one under the cover near the air filter.
If that has no effect, then connect a piece of wire from the + terminal of your ignition coil to a small 12V bulb (other side of bulb to earth), and position it so that you can see it when driving.
