316 poor fuel economy
Emm3
Post Tue Dec 26, 2006 3:41 pm
E36 316i but i assume they use the same engine as the e30. This car prob has the worst fuel economy i've seen for such a small engine it does about 70 miles to 20 quid of fuel and thats local driving. The car is showing 132k with history and its just been serviced by a bmw specialist. The only thing i can think that might relate to it is that it takes atleast half an hour of constant driving from cold to warm it up. Is this normal? as i think it will be using a richer fuel mixture until warm up...........help guys.
Post Tue Dec 26, 2006 3:49 pm
Early E36s used the same M40 engine as the E30, but not later ones.
You're probably on the right track with your diagnosis. Sounds like it needs a new thermostat.
Emm3
Post Tue Dec 26, 2006 4:00 pm
Is it a big job to change
Post Tue Dec 26, 2006 5:48 pm
Emm3 wrote:Is it a big job to change
Fairly easy. Just have to remove the water outlet elbow at the front of the engine (the one that the top radiator hose is attached to), and it just lifts out from behind it.
Access it a bit restricted, so it helps to remove the viscous fan assembly, and the radiator comes out easily as well.
romario
Post Wed Dec 27, 2006 11:32 pm
Defo sounds like somethings not right. i have a 95 E36 316i as my everyday car and consistantly get 275-280 miles from £30 doing mostly motoray driving.
