The mad reason for this is that this is my track car, as these were both options when the car was new I pressuming that they can be removed and the car will still run as normal.
Electric Help
funky-monkey
I want to remove the OBC and Check control panel wiring out of my car
I have a 325 late motronic. Can this be done and still use the car I.E the ECU will still work and engine will still work.
Yes.
You can remove the OBC and its wiring totally, but you will have to reconnect the ignition supply by linking across two green wires to a white two pin socket at the top of the glovebox.
You can't remove much of the check control at all - just the box in the roof, which is hardly worth it.
The wiring for the check control is part of the main car body loom, you can't remove the water or oil level sensors as that will leave large leaks, and the relevant lights won't work if you remove either of the lamp failure modules.
funky-monkey
I have already removed the leccy windows, doors, boot and sunroof wiring which was quite a bit. I'm also planning to refit the engine fuse box into the cabin as it is in the way of the front strut and I will have a roll cage going in there soon( just to be safe). So if i remove the OBC and the cooling and heating system that should be about it then for electrics. I am however planning to have individual oil pressure/fuel pressure and water temp gauges with sensors.
funky-monkey
Thanks for the info guys, so is that the green wire and the red and green wire on the ignition switch to the white 2 pin plug which goes into the engine.
