who sets a gap between throttle body housing and butterfly?
liam012
Post Mon Dec 25, 2006 10:30 am
getting conflicting do's dont's and maybe's on this one.
quite simply - should there be a gap between the butterfly and throttle body housing or should it be closed tight?
i figure if it closes tight the icv has a lot of work to do regulating the idle so can see the sense in a small gap to allow the icv to work within a smaller range and therefore provide a better idle.
interested to know this , especially what bmw specify if anyone knows for definate.
so far i have only got a few "i heard you should do this" etc
Post Mon Dec 25, 2006 10:48 am
You're correct in thinking that the stop screw should hold the throttle butterfly slightly open, and the short answer as to how to set it is DON'T. It was set at the factory to the correct position.
There must be a BMW spec for how to set it, but I've never seen any reference to it anywhere, except "don't touch".
If I came across one that had been got at, I think I would remove the ICV, block both its ports, and unscrew the stop screw until idle speed dropped to around 400 - 500 RPM or so, then adjust the throttle position switch to suit.
This is only a guess - maybe totally wrong.
liam012
Post Mon Dec 25, 2006 10:53 am
thanks brain that was pretty much going to be my experiment for the day!
ur right in the stop - its only an adjustmet to make sure the butterfly does not contact the housing
it is not to be used as an idle adjustment
in fact if i am right in thinking woyuldn't you have to reset the tps every time you monkeyed around with the stop
anyway got hold of mr bently who concurrs with all the above and states a .04mm or .0015" gap.
Post Mon Dec 25, 2006 10:59 am
The Bently manual covers it then, does it? Gap of .04mm between what?
Tps should be set after any butterfly adjustment.
liam012
Post Mon Dec 25, 2006 11:10 am
covers it briefly with specification just under air flow sensor in fuel system 6.1.
roger that on the tps
merry christmas and thanks
