hi all merry xmas.
now i need to get my head unit out so i can put a nice pioneer item i scored for christmas i can do all the wiring and so on but how do i get the standard unit out? i think i gotta put sum things in the holes under the flaps but i cant work it out any tips or do i need sum special tools?
thanks
head unit removal?
Depends on what you've got there already, but "standard" radio removal tools consist of two U shaped pieces of steel wire with notches in the ends that you put in the holes until they disengage the fixing clips, and then use as handles to pull the unit out.
Can be done with a small screwdriver or two, especially if you can get a finger or two behind the unit (from the glovebox) to provide some forward pressure. Much easier with the correct tools.
mark_i
Hi WerkdE30, coathanger wire is perfect, 2 pieces 30cm long, bent to a U shape and the two arms then enter the release holes.
jon_pure_british
i quite literally ripped mine out without the proper tools! lol
Clacton-On-Sea
Essex
Essex
mybmw6
I did exactly the same to get mine out. I tilted the wire towards each edge (ie top hole push the wire towards the top, and bottom hole push the wire towards the bottom). You hear a click noise when it disengages at each point. Hope it helps.mark_i wrote:Hi WerkdE30, coathanger wire is perfect, 2 pieces 30cm long, bent to a U shape and the two arms then enter the release holes.
Matt
