318is Brake servo position adjustment
appletree
Post Sun Dec 24, 2006 10:01 am
Hi
Can anyone help, as you may be aware I am fitting a supercharger to my Is and both the s/c and the brake master cylinder want the same space. I was wondering if it mite be possible to pack the servo mounts to tilt the servo and thus drop th front end of the brake master cylinder down 1 to 2 inches, matt :D
Post Sun Dec 24, 2006 11:01 am
I've moved the assembly sideways slightly on my M50 conversion, but it has to be done properly.
Any movement in the master cylinder/servo will ruin the feel of the brakes and will also be a MOT failure.
It's possible to do, I suppose, but will require some fabrication.
Not sure what a downward facing cylinder would do to getting air out of the system.
appletree
Post Sun Dec 24, 2006 11:37 am
how hard way it to move side ways and how much more room between the master cylinder and the origonal posistion.
any helps much apreicated as at the moment i'am abit stuck. :?
Post Sun Dec 24, 2006 11:44 am
I think I moved mine 25mm, which puts the standard servo close to the inner wing, which was enough for my purposes.
If you used a smaller sevo, like the Golf GTi one, you could move it further I suppose. Use a brake pullrod from an E34 5 series.
appletree
Post Sun Dec 24, 2006 12:15 pm
Been looking some more, think it might be possible to make an adaptor plate and rotate the master cylinder 40 to 90 acw (looking from the rear) towards the front of car and then make a longer actuation rod. Its not the servo body thats in the way its the master cylinder, i'm just after some space to fit some elbows to feed a remote resevoir. dont think will be able find enough room to fit resevoir without major work. Any other ideas or comments gratefully recieved.
look at the last to picyures on this post :D
http://www.e30zone.co.uk/modules.php?na ... 0&start=75
Post Sun Dec 24, 2006 1:27 pm
Theres a shorter (Audi?) m/cylinder that can be used, if that helps at all.
Link in the last post won't work for me.
