clutch problems
lynchy
Post Sat Dec 23, 2006 5:22 pm
hi just purchased a mint sport after 2 days noticed clutch had to be pushed hard to floor and was biting when lifted 1mm. 2day after been in traffic, plenty of stop start!!! i couldn"t get a gear . got home ok checked clutch fluid ,top small bottle was dry tried toppin up but took 3 cap fulls to fill had mate pumpin clutch went down a small bit.
does it sound like a clutch? could there b air in clutch as hear a seal goes at m cyclinder or do i need a clutch kit
smithy318i
Post Sat Dec 23, 2006 5:26 pm
Hello and welcome.
It sound though you have a clutch master or slave cylinder problem. It is always advisable to replace both at the same time.
the master cylinder is located just above the clutch pedal, while the slave is bolted onto the left side of the gearbox.
smithy318i
Post Sat Dec 23, 2006 5:30 pm
you will need to bleed the clutch before you can be sure that the cylinder(s) have gone.
the bleed nipple is attached to the slave cylinder.
Post Sat Dec 23, 2006 8:37 pm
I'll bet the previous owner isn't surprised this has happened. Are there a couple of brake fluid cans in the boot?
It's just possible that the hydraulic hose to the slave cylinder has split, but it's almost certain you need a new clutch master and slave, as smithy says.
lynchy
Post Sat Dec 23, 2006 8:43 pm
no boot empty !!! no more honest people out there sell problems on !! is it a common fault in the e30 any idea how much ud pay for master and slave?
Chris-W
Post Sat Dec 23, 2006 9:26 pm
Around £80 from the likes of Eurocarparts.
fuzzy
He who sleeps with "Gingers"
Post Sat Dec 23, 2006 9:36 pm
yes they are about £30 odd quid each from ECP.easy enough job to do :wink:
Post Sat Dec 23, 2006 9:52 pm
GSF have the pair or about £45 in their cheepo range. The better ones come to about £80.
Taz
Post Sat Dec 23, 2006 9:56 pm
the cheapo gsf ones are quite good...i had both of mine done 2yrs ago and had no issues since then
mybmw6
Post Tue Dec 26, 2006 1:31 am
lynchy wrote:hi just purchased a mint sport after 2 days noticed clutch had to be pushed hard to floor and was biting when lifted 1mm. 2day after been in traffic, plenty of stop start!!! i couldn"t get a gear . got home ok checked clutch fluid ,top small bottle was dry tried toppin up but took 3 cap fulls to fill had mate pumpin clutch went down a small bit.
Sounds like my issue, I found it really hard to shift into gear. I just did this job on my 325i. As stated above. Best to do both at the same time. I did the master first by itself and the problem seemed to be fixed. Two weeks later it happened again and it turned out to be the slave, the seal around the slave shaft was worn and air was letting in.
If your reservoir was dry then you've more than likely got air in the system. Has to be bleed anyway when you fit the new cyliners. I'd check/replace these first before worrying about a clutch kit.
