VHT laquer??
blingsta
- Boost Junkie
Can anyone tell me which would be the best laquer to use for my rocker cover, ive sprayed the cover with VHT spray paint and it looks good, but i want to protect it by using laquer too.. i tried some before but it went all yellowy due to the heat and kinda melted away!!! is there a certain 1 i should be using?
fuzzy
what colour are you doing it? i just used white high gloss radiator paint from b+q to do my rocker cover.no problems so far
blingsta
- Boost Junkie
ive sprayed the rocker cover in met black but want to laquer it too... is there a high temp laquer available?? last one i used which was out of a spray can turned yellowy and melted away!!
maxfield
my dad peeled the laquer off due to this but the paint will cope with the heat but wont look so good if you don't keep it polished
d6dph
Hycote do a VHT lacquer mate, http://www.saxonind.co.uk/hycote-vht.htm
Should be available from most motorfactors.
blingsta
- Boost Junkie
cheers Dave...
