hi junkies
need an oil supply for a garret and a t-piece
1, what is the thead on the garret ?
2, where do i get a t-piece & what theads ?
cheers matt
Turbo oil supply
Ant
- Retired Team Member
oil pressure T piece is :
M12 x1.5 x2, with M10 x1.0mm on the oil feed side, £7 quid or so from Rallyedesign or Demon theives
T3 should have an M10 x1.0 fitting on it too, normally use an adapter to go M10 to AN-3 decent hydrauilc hose place or anywhere that makes braided brake hoses will be able to supply dude.
HTH
HTH
Email FTW
