diesel crank
nikos
Post Tue Dec 19, 2006 2:40 pm
anyone knows if the diesel crank needs balancing and lighting and how much for the 2.7 conversion? and what is the speed limit that can spin?
1991 325 cabio t/c 3.2 evo, 6speed, e36m3 rack, adj bilstein,
http://s241.photobucket.com/albums/ff262/granitsas/
chu346
Post Tue Dec 19, 2006 4:26 pm
It shouldn't need balencing but it always helps.
Speed limit should be whatever you want because the rockers will break first anyway.
Cost can vary between 250-3500 pounds or more depending on how you want to build it and how much work you can do yourself.
Ant
Retired Team Member
Retired Team Member
Post Tue Dec 19, 2006 7:28 pm
its a V heavy item, and some lighteneing is a good idea, you'll never break it dude so no worries there :thumb:
requires specific bearing shells too , std wont last that long, the crank is hard as steel ( literally :lol: )
Turbo-Brown
Boost Junkie
Post Tue Dec 19, 2006 9:11 pm
Hmmm. The bearings shouldn't wear except when the oil pressure's low i.e. when cranking, and even then it's the surface finish of the journals and not the material that'll determine whether the bearings die quickly or not.
Ant
Retired Team Member
Retired Team Member
Post Tue Dec 19, 2006 10:56 pm
totally agree Alex, but the TD crank has specific bearings on the ETK, material must be different as a result, the dims are identical, and the petrol M20 bearings share common dims too.
I have used the correct ones as specced on a customers engine very recently, seemed only right to use the OE parts .
I have some M21 big end shells in the unit, again the same but not, you're welcome to a couple for comparison m8, be nice to see why/what is the difference.
Turbo-Brown
Boost Junkie
Post Wed Dec 20, 2006 12:17 am
Would guess that the ones for use in the diesel are the copper based ones which will take more of a pounding at startup as you'd get in the diesel application, whereas the aluminium based ones I'd imagine would be fine for petrol usage :)
Problem with the copper ones is the imbedability isn't as good so if something hard finds its way into the oil system, it sticks out of the bearing and scores the crank rather than sinking into the bearing material and leaving the crank alone.
As you say though dude, if BMW specced it, it should be fine :)
