couple of queries....
1 My rear window demisting is shot.....all bars seem broken and testing has confirmed this, do have 12volts at the lhs and a good earth at rhs, the question is when the side lights are on should the rear screen switch be illuminated, as it only lights up when switched on, is there an internal bulb etc.
2 Car is 1989 Sport and could do with a spare ignition key, it doesn't look or feel like a key that has a chip in it, is this correct, and is it a cheap fix to obtain one.
heated window switch and ignition key query
GDBN
1. No - but you can modify the switch so it works like the hazard switch.
2. No chip - any decent key cutter place can make you one from your original.
G
G
k
Thanks for quick response.....whats the mod, how do you do it?
GDBN
IIRC - you need a "donor" hazard switch - change the front from the rear demister to the hazard switch. Then you have to loop a wire from the positive feed ( the one that lights the bulb permanently - can't remember which one it is) from the existing hazard switch to the new one.
Look under articles above or do a search on the zone .
G
G
