Speedo pod illumination
316eyes
Post Mon Dec 18, 2006 11:39 pm
The brightness of the illumination on my dashpod has gradually become dimmer, to the point that, even with the headlight knob turned up fully, it's very dark in there.
I am assuming that this is down to the 18 year old bulbs being on their last legs.
Can anyone post up a pic of the rear of the cluster showing which bulbs I will need to replace?
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
smithy318i
Post Mon Dec 18, 2006 11:50 pm
the big ones on the left/right
316eyes
Post Mon Dec 18, 2006 11:53 pm
Cheers Smithy.
I assume you have to take the pod apart to change them, as you've put up a pic of the insides.
smithy318i
Post Mon Dec 18, 2006 11:57 pm
no need to take ot apart (thats just so you can see which ones to change better)
edited away now.
in fact, if you have small enough hands, you can probably change them without removing the cluster. (v small hands)
316eyes
Post Tue Dec 19, 2006 12:01 am
"in fact, if you have small enough hands, you can probably change them without removing the cluster. (v small hands)"
Might as well take it out and make sure the dreaded backnuts etc. are all tight.
Thanks mate.
