Coupe vs Cabriolet
323i_rare
Post Sat Dec 16, 2006 8:42 pm
I am interested in comparing the performance between the two. Will the difference between a 325I sport and a 325I convertable be similar?
All I can think off is straight line speed will be a little slower i.e. .2 seconds longer to get to 60 due to the extra hood weight.
And also what would it be like around bends? less rigidity of the cab, is it really noticable...
BIGJO
Post Sat Dec 16, 2006 8:49 pm
Don't think there'll be that much difference in 0-60, easily less than 2 seconds I think.
Not sure.................
Regards, BJ.
323i_rare
Post Sat Dec 16, 2006 9:02 pm
BIGJO wrote:Don't think there'll be that much difference in 0-60, easily less than 2 seconds I think.
Regards, BJ.
That was .2 seconds mate, as in 0.2 seconds...
BIGJO
Post Sat Dec 16, 2006 9:11 pm
Oh sorry fella...
mrLEE30
Post Sun Dec 17, 2006 6:17 am
its not the hood that weighs more (metal roof is heavier than a fabric roof!!) its the additional bracing to sills, under rear seat, behind rear seat, across the lower windscreen and in the engine bay/suspension turrets that adds the extra weight. in a stright line accelleration it will not be noticable (or i should say less noticable then the difference between two different engines) on the twisty bits you may notice a difference as they will inherantly be less ridgid, but again no two coupe cars are the same, tyres, suspension, wear and tear, etc all play a part in how a car handles, fitting strut barces and ARB front and rear to a cab will stiffen it up, compare that to an old standard coupe and the cab could be better!! top speed and fuel economy with roof down will deffonately be affected, and if it rains you get wet in a car with no roof!!
mrlee
orangecurry
Post Sun Dec 17, 2006 8:30 am
mrLEE30 wrote:fitting ARB front and rear to a cab will stiffen it up,
mrlee
why? doesn't it have them already? winkeye
I thought we 'agreed' that fitting strut braces to a cab was a bit of a waste of time, due to all the extra bracing in those areas already (as you detailed above)?
Ziggy
Post Sun Dec 17, 2006 1:53 pm
mrlee
Thicker ones than the coupe too... :)
Simon
Post Sun Dec 17, 2006 2:23 pm
E30 coupe, never heard of such a car, anyone got a pic of one? :P
richard300
Post Mon Dec 18, 2006 9:45 am
i have had a couple of both in the past.... and its like this, if you really want a soft top then the scuttle shake and the extra weight and anything else you care to throw at it doesnt matter, because you will just love the fact that you are rolling with your hood down :D and the heaters are good enough that with the four windows up you donr need to have the roof up no matter what time of year it is!! unless its raining and even then i was once driving down the m40 with the roof down and it started to rain, just up the speed a little and didnt get wet at all :D oviously i would have been stuffed if i had got caught in traffic, but then i could have just put the hood up....lol
325i Motorsport Convertible (For sale)
Jaguar XJ8 4.0 V8 SE
Mercedes CLK Kompressor
(AMG Sport pack)- NOW SOLD
Renault Sport Clio RS172
Ropey o
mrLEE30
Post Mon Dec 18, 2006 9:50 am
alright smart arses, i meant thicker ARB's i.e aftermarket ones and i meant rear strut brace... but yes i agree they will do little or nothing....and any way i said strut barces to be attched to any one of the seven tilletbrackets, these are special parts only i know about...
I would also argue that the dutch 2 door touring conversion could be classed as a coupe (2 door, fixed roof, sloping back) . A picture i will find if you dont know what one is :roll:
mrlee
richard300
Post Mon Dec 18, 2006 10:01 am
or would it be classed as a 'shooting break' ?
Ropey o
orangecurry
Post Mon Dec 18, 2006 10:04 am
mrLEE30 wrote: any way I said strut braces to be attched to any one of the seven tilletbrackets, these are special parts only i know about...
I would also argue....
mrlee
you? argue?
I thought there were only 6 tilletbrackets?
mrLEE30
Post Mon Dec 18, 2006 11:20 am
yes there are 6 on the 2 door, fixed roof models.
But i am refering to modifying a cabriolet, those have seven tilletbrackets, the seventh is attached to the left hand upper swinging bobbit arm(s).
OC hey look you are almost a squatter.... look at my 24 hour pics in pub talk i so kindly downloaded for you and make a load of comments and together we will break this terrible camper affliction :wink: oh hang on posts dont count over there!! i'll get me cloak!
mrlee
