hey people.. just wondered if anyone knows if the big tech 2 steering wheel centre will fit the into the small tech 2 steering wheel centre? or how much it would cost to buy the centre (for a small 1) for the steering wheel...
..marvelos..
m tech 2 steering wheel...
mrLEE30
not sure what you mean..... a big tech 2 wheel from an E34 will fit onto the spline of an E30, get it straight, add the washer and nut tighten it up and bobs your uncle.
what do you mean by steering wheel centre??? do you mean the horn /cover part?? if so i would be tempted to say no but not sure about this. if they are different it would be cause the big tech2 is bigger and so the horn/cover would be bigger to match
Chris-W
marvelos
hey chaps.. what i must mean reading your replies is that i have an e34 tech 2 steering wheel with the longer spokes.. and by the centre i mean the horn push bit. i wanna know if the horn push bits r the same, as someone has a tech 2 with out the horn push and i wanna know if i can use the horn push from my bigger steering wheel.. u get me know mrlee30? and i also how much am i looking at to buy a tech 2 horn push..
thanks again people!
marvelos
oh and chris when u say centre pads are we talking about the same thing.. ie centre pad=horn push?
thanks m8!
thanks m8!
