dead central locking
SPADGE
Post Thu Dec 14, 2006 10:19 am
Hi all
One of my tourers, that i am in the process of fixing-up, has dead central locking for some reason? I have replaced the module with a known good one and still there is no life in it when i turn the key in the drivers door or the boot :? The electric window in the drivers door also doesn't work so i don't know if this is related? All the wiring going to the door looks ok but i havn't looked inside yet. Is there a way to test that the wiring going to and out of the module is ok?
Cheers Spadge..
eltel
Post Thu Dec 14, 2006 12:55 pm
i had similar probs with my 325 as most do.... once it was the module in drivers footwell under speaker, another time it was corroded pins in the A-pillar door connector...and the last time it was the drivers central door locking motor.
when you turn the key in the lock, the motor needs to work to activate the module and the pins in A-pillar need to allow the connection.
id pull back the rubber cover on a pillar, clean the pins and spray with wd40
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
eltel
Post Thu Dec 14, 2006 12:56 pm
p.s ..as the window also doesnt work id defo say A-pillar pins
SPADGE
Post Thu Dec 14, 2006 2:05 pm
Hi mate
I have just cleaned the plug connector in the pillar as the window on the drivers door wasn't working either. The window now works but the c/l is still fecked :?
Cheers Spadge..
eko
Old timer
Post Thu Dec 14, 2006 5:01 pm
SPADGE wrote:Hi mate
Cheers Spadge..
Have you tried the trick with the Red/Black wires?
If not it goes like this........
Remove drivers footwell speaker,unplug the main plug from Apiller to door then unclip the plug holding it to the A piller.
There will be 2 Red/Black wires going into the plug,you need to cut them both from the plug and rejoin them back together,hence bypassing the plug.
Put it back together and chances are itll work!
All this Red/Black wire does is go into the door,loops around and returns back out.
Very common problem!
Hope this helps :)
DaveD
E30Zone Wiki Specialist
Post Thu Dec 14, 2006 5:05 pm
i went and got a new (better condition, not corroded, second-hand) plug and rewired the whole lot ...hard wired the dreaded red/black wire and its worked ever since...just cut the wires with as much as possible on the new one and mated them up to the ones in the foot well
SPADGE
Post Thu Dec 14, 2006 8:34 pm
Cheers Spadge..
Hope this helps :)
I'll give that a go tomorrow cheers mate :thumb:
DJ_B4L
Post Thu Dec 14, 2006 8:39 pm
yeh it will def be the pins happens its a common problem after you put it back to together put sum kind of sealant that will keep the water out.
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
Post Thu Dec 14, 2006 10:22 pm
Buy a pot of silicon grease and use this generously inside the plug and socket when you put it back together.
Definitely do the red/black wire modification - the corrosion inside the door plug and sockets is not random, and is actively promoted by the presence of this red/black wire.
The next most common pin inside the door connector to fail is one that makes the door mirrors move. The window ones don't usually give trouble unless the rubber boot hasn't been put back properly in the past.
Window problems are usually the relevant switch.
SPADGE
Post Fri Dec 15, 2006 8:02 pm
Eko and Brian
Spot-on again fella's :D
It was the plug and the terminal for the c/l had detached itself and so joining the 2 red/blacks did the trick!
Also gave every remaining terminal a good clean and the mirrors now function 8)
Thanks guys!
eko
Old timer
Post Fri Dec 15, 2006 8:10 pm
Glad you got it sorted mate :)
SPADGE
Post Fri Dec 15, 2006 9:19 pm
eko wrote:Glad you got it sorted mate :)
Cheers mate :)
I took a couple of pics of the connector 8O
Post Fri Dec 15, 2006 9:29 pm
Had the same sh*t going on with my '87 320iSE...Halfords contact cleaner spray helped remove most of that green gunk, but the pins still needed delicate cleaning with a jeweller's screwdriver. One in fact snapped off so I had to 'hard-wire' it.
