s50/m50 manifold?
bigkev
Post Wed Dec 13, 2006 11:23 pm
does anyone know if the exhaust manifolds are interchangable between these two engines
jmc330i
Post Wed Dec 13, 2006 11:27 pm
The port sizes are very different - S50 much bigger, but the bolt pattern is the same AFAIK.
James
'91 325i Sport
'93 318i touring 16v
ste
Post Thu Dec 14, 2006 10:03 am
They are interchangeable.
As JMC says you wouldn't want to put an M50 manifold on an S50 - going the other way is fine though. ideally you'd port match the head to the manifold too.
bigkev
Post Thu Dec 14, 2006 10:22 pm
was just thinking of buying a steel m50 one for the flanges to cut off so i can build a turbo manifold a bit cheaper once they are cut off i can match them up precisely before welding up or (so the plan goes) :?
jaistanley
Post Thu Jan 18, 2007 1:28 pm
Sounds like an idea. Remember its the M52 (2.5 and 2.8) engines that have the steel manifold, the rest have the cast iron ones which would be a pig.
I have seen some turbo manifolds for these engines on ebay recently that look awesome value (£150 rings a bell). I emailed the guy and he told me they place the turbo up, and toward the front so the only trouble you should have would be with the downpipe (if yours is a RHD).
Jai
Post Thu Jan 18, 2007 10:05 pm
Im pretty sure the M52 manifolds are also stainless :?
ste
Post Thu Jan 18, 2007 10:08 pm
They are stainless - I think that's what Jai meant.
jaistanley
Post Fri Jan 19, 2007 1:34 am
Yea sorry,
Just re-read the post and it's garbage! I meant to say you need the M52 ones.
That's using the zone at work for you.... :o:
Jai
