Thinking about doing a BBTB conversion - advice needed...
E30mann
Post Wed Dec 13, 2006 8:25 pm
Hey all, long time no see - been stuck in college - off for Christmas from Fri on so looking forward to getting stuck in on the car! winkeye winkeye
Looking to do a big bore throttle conversion on my (metal bumper) 320i - a mate has a (later model) 325i TB, rubber AFM to TB sleeve and idle speed valve - mines the old H type water heated valve.
what I wanna know is, before I start boring out my inlet manifold, there seems to be a slightly different layout on the TB itself - the pipes come at it from a different side, and the lever on top is mounted higher, without the extra bit on the lever. think I can swap it over from my old one and bend it slightly so the vacuum piston(?) can hit it - i think...
is swapping to a later TB possible? If I connect all the hoses correctly, will this work? I have heard of swapping an earlier model idle valve for a later one (hooking the later one up to an existing switchable power source and joining the water pipes, bypassing it completely) but only like for like - 320i for 320i, but haven't seen anything on this conversion, am still hoping it can be done?
also, if it can be done, what fits in the rubber sleeve between the AFM and TB - cant figure out what goes where at this early stage!
any and all help gratefully appreciated, hopefully if this is possible will go at it over the weekend..........
georob
Post Thu Dec 14, 2006 11:31 am
Theres a guide in the articles section im sure bud
E30mann
Post Thu Dec 14, 2006 9:37 pm
Yeah looked at it there doesn't seem to be anything on it..... come on everybody!........ Tell me SOMEBODY! .....surely the zoners haven't lost their touch???? :?: :?: :?:
Post Thu Dec 14, 2006 9:43 pm
Sounds like you're trying to fit a later Motronic-type TB onto an early L-Jetronic 320i...not sure if it's do-able.
Cloggy Saint
Post Thu Dec 14, 2006 9:57 pm
And there's no real point in doing it unless you open up the inlet manifold to match the larger bore of the throttle body.
