front wiper motor...
fuzzy
He who sleeps with "Gingers"
Post Wed Dec 13, 2006 7:42 pm
replaced a front wiper motor today after it packed in on the way to work,the scrapyard replacement packed in half way home.it was stopping then starting halfway through its swipe in the middle of the window before its stopped completely .does it sound like ive been unlucky with a duff motor or something else completely causing it.ive changed the relay with no change. :?
fuzzy
Post Wed Dec 13, 2006 8:08 pm
just been out for another look,the spindle in the centre of the motor seems loose and it making a buzzink noise as soon as i switch the wipers on.
e30bemer
Nutters
Nutters
Post Wed Dec 13, 2006 8:12 pm
could be a dud motor, try and trace another one!
thats what i did!
will look in the shed, think i have one, was given two, when mine packed up!
but did recently sort the shed out, so i might have slung it!
but will let u know!
Post Wed Dec 13, 2006 9:45 pm
Look in the articles!!!
Chris-W
Post Wed Dec 13, 2006 9:48 pm
Are you absolutely sure the wiper arm - nut on motor shaft is adjusted properly?
bmwe30mtech
Post Wed Dec 13, 2006 10:14 pm
Sounds like a duff motor. The connections in them get dirty, then they will have a bit of a mind of their own when switched on, for example as you say stopping in middle of screen.
Connections can be cleaned but easyier to try another motor.
Also you checked that the 'threaded' bit where the motor attatches to the wiper arm isnt stripped?
fuzzy
Post Thu Dec 14, 2006 6:53 pm
DanThe wrote:Look in the articles!!!
i did try that first but got over 2500 posts related to front wiper motors,quicker to ask again i thought winkeye
what do you mean by wiper arm nut adjusted properly :? i changed it in the dark,in the rain so its possible ive not done it correct :roll:
320Touring
Post Thu Dec 14, 2006 6:56 pm
fuzzy
Post Thu Dec 14, 2006 6:57 pm
320Touring wrote:http://www.e30zone.net/modules.php?name ... wipers.htm
Articles, not forum :wink:
oops :o: thanks neil,i take back everything ive said about you winkeye
