maybe buying a 320
trentdarby126
Post Wed Dec 13, 2006 6:14 pm
hi, im new to all of this and was just looking for some help, im thinking of buying a 1988 320 auto, its a two door, the guy says it was a special model although i cant remember the name he said, its done about 100000 miles and seems well looked after, are there any major mechanical problems i should be looking for, and what are the parts prices like, what sort of things are likely to go wrong with the car and is it going to cost me a fortune to sort out ect. tried looking for a reveiw of the car and people seem quite positive about it. i really would like to pop my bmw cherry but i cant afford to pay a fortune for parts ect. the car is selling for 900 pounds, is that reasonable. please help
Knobead
Post Wed Dec 13, 2006 6:58 pm
Hi there the only costliest thing i can think of to go wrong is the head gasket , these are expensive work as there aluminium and can cost to replace, sit the car on idle and make sure the gauge does not go over half way even under revs should not make it go over half way. I'm only talking from bad experience with mine.
Just be sure its had loads of tlc hope this helps.
Chris-W
Post Wed Dec 13, 2006 7:02 pm
Best thing I can suggest you look for on that car, if it runs well, are an absence of rust and a recent MOT.
Splondike
Post Wed Dec 13, 2006 7:03 pm
It needs to be a very good one for that sort of money. 320s being the most unloved unless in Touring guise, the auto box will dent the value as well as this is the thirstiest model of the bunch, on the up side the 320 is silky smooth. If it is a genuine 100,000 miles and is clean and historied then it sounds ok. Parts are generally fairly reasonable if you use places like Eurocarparts and German and Swedish etc, although it's worth checking with the main dealer as parts can be surprisingly cheap and be of better quality. That is what I have found, but it depends what you are comparing it to ?
Have a look through some old posts as this question is asked all the time. Search the for newbies and through the tech nical section.
Oh and welcome :wave:
Mark.
J_Mac
Post Wed Dec 13, 2006 7:28 pm
normal checks i do when buying
engine running .. temp as Knobead said
or mayo in the oil
steering full lock both ways .. any unusual noise, i.e knocking
wear on tyres and where .. inner wear is the camber
and after a few min running and a few min engine off .. under the car for leaks
there quite expensive fix's other bits rust ect you weigh in with the price (do all the small fix's justifiy the price)
the autobox is not something i'd go for ... manual is fun
mine was up for £900 and i offered £700 after i saw inner wear on the rear tyres and he took £750
few minor bits i'm working on now but i enjoy working on it myself
you probably could find one somewhere else for 900. shop around .. look on the car's for sale on here
there loverly cars mate you won't be disappointed
trentdarby126
Post Wed Dec 13, 2006 7:44 pm
thanks for the help guys, im going to go check it out in the next few days, but ill keep an eye out for others lurking around the area, and ill look out for the things you guys listed, cheers
