i am wondering how much of my car i am going to cover with 36sqft? i hope to do all the floor bulkhead and transmisssion tunnel, behind the two foot speakers and line the doors and rear arches? is there a hope in hell in having any left for the boot
aimed result is low noise cabin noise with that "whooshbup" when you close the door knowing you have just sat into a quallity vehicle!
just ordered 35sq ft of dynamat extreme - best use?
dark_sounds
no chance,,,
36sq ft will just about to the boot,,,,, ;) i had a thread somewhere where i used 36 sq feet and it just covered the boot floor and boot rear quaters not even enough left over to do the lid...
you need a second pack...
thought about using second skin damplifier pro,,, its cheaper, and proven to be better...especially at ultra high tempretures...
www.sounddeadeningshowdown.com (i thin kthats it,, if not google it! )
damplifier normal and damplifier pro.... both beter heat properties... maybe transmission tunlle and bulkhead where the heat is..
also for floor plan mabe use the normal damplifer non pro,, cos after you got the carpet on i dont think youll notice must difference as the mass loading will take most of the effect use the pro stuff on bulk head, doors, and quarters. save a bit of money too... could always bulk it up with sludge
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
liam012
oh sh1t
the web site said 5sqft would do a door and i figured i'd have loads
will look into the other stuff
thanks
thanks
