Hi all,
Last night I was reversing slowly parking up, then took car out of gear and let off clutch and the car jerked backwards.. Hmm... She's still in gear.
Tried all manner of things but basically the gearstick feels like it's in neutral and feels like I can't select any gears, not even reverse, but the gearbox is actually in reverse since when I lift the clutch it drives backwards.
Before this it was a hassle to get into reverse anyway and I'd have to apply left pressure whilst wiggling the stick a bit forwards/backwards then it would slide across and engage reverse fine. Every other gear was always perfect.
Any ideas guys?
http://www.realoem.com/bmw/showparts.do ... g=25&fg=05
This diagram lists the selector mechanism, and a mechanic friend told me to have a look at parts 2, 3, and 4 to check for damage. I'm hoping it's just a selector issue since I can't be arsed to change the gearbox after only having the car a few days! Hahaha.
Any help would be great, thanks!
Car stuck in reverse, gear stick in neutral
Martinaston
Check the engine and gearbox mounts as well to make sure the lump hasn't shifted.
It normaly jumps forward after a front end whack.
There is NO nucleus.
MJG
It was the gearbox, an internal problem. The selector on the gearbox itself would not move anywhere, and was in the neutral position (straight, and in the middle). Fitted a new gearbox and it now works fine. Thanks.
