kangerro petrol
**BANNED**
Post Tue Dec 12, 2006 5:56 pm
Now I have the 2.7 part way run in,I have a rocking,kangerro type effect as I either run at low(idle to1200rpm)engine speeds or slow down with the throttle closed.I reckon it is idle control valve or throttle position switch,the idle is also a little fast at 900rpm,how can I ajust this?Would a rolling road session to fine tune the zone chip to the ECU help?
maxfield
Post Tue Dec 12, 2006 5:58 pm
cheack for leaks in the pipe after the afm
and clean the icv in carb cleaner
Martinaston
Post Tue Dec 12, 2006 7:22 pm
and then replace the clutch.
There is NO nucleus.
**BANNED**
Post Wed Dec 13, 2006 5:58 pm
Saw the thread on this the other week.I had just put the whole lot back!!The clutch plate looked fine,this is the problem that us amutaur(?) mechanics have,how do you tell when something like a clutch plate is going to cause a judder like this?Still clinging to the vague hope that maxfield is right(for once)and it is an air leak!!Should the ICV have hose clips?Mine has always been a push fit?Is it that simple?
Martinaston
Post Thu Dec 14, 2006 8:04 pm
Its not the friction part that causes it, its the four springs in the centre that wear out and bounce backwards and forwards. You can't get the bastards out because there riveted into the plate so it means a whole new clutch :-x
The ICV just plugs into the hoses but they tend to go a bit brittle with age and can leak. I normaly smear a bit of silicone around the lip, just make sure you don't smear it IN the hose. (fingers crossed)
**BANNED**
Post Fri Dec 15, 2006 7:42 am
I put new locking nuts on the manifold yesterday,and hose clips on the ICV where the short pipe is.This has reduced the kangero effect.I left the ICV conection to the intake bellow alone,it has on odd shape that a hose clip will not sit on.Thinking about it at work last night I will try a touch of silicone on it.The clutch plate looked OK,plenty of life in the lining and no obvious wear in the springs.I find it a constant problem as an amutaur to tell when a component is worn to its limit!!
Martinaston
Post Fri Dec 15, 2006 11:47 am
The only way to tell if the springs are worn is to leave the clutch assembly attached to the engine and put a lever through the centre (where the gearbox input shaft goes) and try to turn it, you'd have to find a way of locking the crankshaft in place and then work out the amount of force needed to compress the springs. (i.e. the weight of the car on a new clutch) They only have 18 degrees of movement but that would only be used at full power when you drop the clutch, so at lower engine speeds on a worn clutch they'll rattle around if they've lost tension. But to be honest who's going to go to all that bother to check a clutch plate while on the car. Even if theres a way of doing it once its removed from the car you might as well just replace the thing anyway.
All because of four poxy little springs :x
