Wheel Bearing Query
Jesus325iTouring
Frog freak !
Frog freak !
Post Tue Mar 29, 2005 8:01 am
Looking on Euro Parts site they have these two bearings,both for cars with ABS,does anyone know the the difference between the two,or is it just a quality thing?
OMCAR n/a 628110150 FRONT WHEEL BEARING E30 ABS E30,RANGE (WITH ABS).ZI,11/88-
WITH HUB Ԛ£39.75
n/a 628110151 FRONT WHEEL BEARING E30 ABS .
WITH HUB Ԛ£17.95
E30Mark
Post Tue Mar 29, 2005 8:26 am
One's OE the other ain't!
http://www.eurocarparts.com/part_number.htm
If you have more than one part number showing on the search results page - check the first 8 digits, if they are identical in more than 1 of the parts showing, the difference between them is their make. For example: 332456780, 332456781 and 332456785 are all water pumps for a Saab except '0' indicates 'Original Equipment Manufacture', '1' indicates 'Alternative Quality Brand' and '5' indicates 'Genuine Part'.
PM for details
Jesus325iTouring
Frog freak !
Frog freak !
Post Tue Mar 29, 2005 10:25 pm
Cheers Boss,thats the second time you've cleared up some techy questions for me :D :D :D :D
E30Mark
Post Tue Mar 29, 2005 10:37 pm
And my g/f says i waste my time on the PC!
We're all here to help each other, whilst i'm at it do you know anything about working pig farms? got a college assignment to do...
PM for details
Jesus325iTouring
Frog freak !
Frog freak !
Post Tue Mar 29, 2005 10:39 pm
E30Mark wrote:And my g/f says i waste my time on the PC!
LOL,you can the missus you've been helping the Lord!
Pig farms,I might be able to help,been a long time,what do you want know?
E30Mark
Post Tue Mar 29, 2005 10:46 pm
Here's one for starters!
Due to a sudden drop in temperature, the pig man sets up additional heating by means of portable Edison screw (es) type heating lamps, fed from the socket outlets at the back of each pen. As there is an insufficient number of these lamps he improvises, using lengths of two-core unsheathed cable fitted with a plug to BS EN 60309-2 at one end and a Edison screw lamp holder at the other. After fitting a 150W lamp, the pig man connects the lead to the supply and supports the lamp by knotting the cables around the metal frame of the pen. To reduce heat loss, the floors of the pigpens are insulated with straw.
State
a) THREE hazards that have been created by the actions of the pig man
b) TWO statutory requirements that are infringed by the pig manÔš's actions.
Don't actually need to know anything about pigs, i'm studying electrical installation, and this is one of the college assignments :roll:
PM for details
Jesus325iTouring
Frog freak !
Frog freak !
Post Tue Mar 29, 2005 10:57 pm
E30Mark wrote:Here's one for starters!
State
1)You would never have electric "inside" a pen.
2)Unsheathed cabled?? Is he insane,pigs'll chew anything!
3)Knotting the cables around the metal frame could cause the wire to heat up and melt,as the cable is unsheathed as well,the cables will eventually melt and the wire will come into contact with the metal frame making it "live"
4)Also,as the lamps are not fixed up correctly if they come down for whatever reason,they'll set fire to the straw.
Statutory requirements?? Sorry Mark,your on your own for this one.
Incidently,I remember my Dad doing just this sort of thing before all the rules and regs!
