320 2 door electrical gremlin
SPADGE
Post Sat Dec 09, 2006 5:12 pm
Hi all
I have a 2 door 320 here that i use as a runabout from time to time.
Ever since i have owned it it has had an intermitant fault where the power windows and heater fan will sometimes not work and the lights on the power window switches will go out. The windows will still work if you open the door however. The fault comes and goes but its a bit annoying especialy in the cold weather as without the fan the car steams up and it seems to be happening more and more at the moment.
I'm guessing this could be something to do with the unloader relay but thats just a stab in the dark?
Cheers Spadge...
Post Sat Dec 09, 2006 6:31 pm
There are two unloader relays, K5 and K7. Windows are on one, and the fan is on the other.
Common link between them is a black/green wire which runs through pin 15 of the C101 connector and then goes to the smallest connector on the starter motor.
Fault is likely to be, in order of probability, the connection onto the starter motor, the connections in the C101, and the starter motor itself.
SPADGE
Post Sat Dec 09, 2006 6:36 pm
Brianmoooore wrote:There are two unloader relays, K5 and K7. Windows are on one, and the fan is on the other.
Ok Brian i'll have a look at it thank you!
SPADGE
Post Thu Dec 14, 2006 8:31 pm
Spot on Brian :notworthy:
The black/green on the starter had worked loose :D
SPADGE
Post Thu Dec 14, 2006 8:32 pm
Ooops forgot to say a big THANK YOU :D
