if the trailing arms on an e30 are the same as on the e36 compact, if the output shafts were swapped and a new set of 5 lug bearings were fitted if poss.. would this be possible?
reason i ask is because ive heard of a e36 compact vented rear disc set-up (alá Demlot ;) ) and it was suggested the 25i.x arms to be used.
could the e30 be fitted in the same way?
hope someone knows ;)
