How do you change a diff ?
Herrity
- Location: Liverpool & Leamington spa ! Drives: Mercedes 190 cosworth & 1990 325i touring
As title really, what do you have to do ? Any tips or tricks to give me ? Thanks in advance !
Dan318-is
Its a simple job just a bit labour intensive. Jack both the rear wheels of tehe ground and support the car on stands You need to undo the four 17mm bolts holding the propshaft to the diff. A second hand to operate the handbrake so you can spin the prop and get to two bolts at a time helps. loosen the 19mm nut/bolt combo going through the guibo but dont remove it. Undo the 12 x 7mm alum key bolts holding the driveshaffts on but use a fookin socket key not a proper alumn as you will just round them. Then, the worst bit is the four 19mm bolts attaching the diff to the subframe; there are two almost directly above the prop which are easy to get to, and two on top of the diff for which you are best to invest in a 19mm ratchet spanner.
Then remove the donut 19mm bolt that you earlier undid, and give the diff a tug to get the flange and the prop seperated. It should really be removed and supported with a trolley jack, having sed that i changed my diff three weeks ago on a sunday on my own without a trolley jack (only had the bmw jack to get it off the floor) and using two 19mm spanners and one 17mm spanner and the 7mm alum key socket/ratchet.
Then just do the reverse to put the new one in! i found putting the flange in place with the prop then threading the donut bolt through made it easier; but do the subframe bolts up first otherwise they can be hard to line up
hth
hth
Herrity
Thanks mate, have full workshop and air tools to use !
Dan318-is
Lucky sod although i dont think even the air tools will be much use on the subframe bolts they are real fuckers! Good luck.Herrity wrote:Thanks mate, have full workshop and air tools to use !
Herrity
A tin of WD40 should sort them, and we have a truck wheel nut gun, it'll either snap it or make the job easier !
WillG
i think he means you wont be able to get at bolts with air tools
Herrity
Oh I see, he means general access to the bolts area !
Dan318-is
comprende heroWillG wrote:i think he means you wont be able to get at bolts with air tools
Nelly
- Gumbo
stuartgallafant
Dan318-is
i went to bed and thought, dam i didnt put that on the thread!Nelly wrote:Dan, you forgot to mention that you also have to disconnect the speed senser loom from the back of the diff - pulls straight out, or you'll end up with a broken loom.
Neil.
if your swapping and early diff for a late dif also the speedo plugs may be different types but can be swaped over i think?
Herrity
No the diff is from the same year car, it was a car theo was breaking a few months back so hopefully it should go smoothly ! I've soaked the general area in WD already this morning so shall attempt to do it this afternoon but first its MOT time !
Dan318-is
good luck my friend!
Herrity
I need it ! Me headlights need re-aiming and handbrake is poo to start with !
