leaking tourer
Cloggy Saint
I've just discovered that the soundproofing under the load area cover is soaking wet
. The water seems to be coming from around the 2 rings that protrude from the rear most trim panel. I've checked the light seals and they seem ok and there is no water in or around the clusters. The water seems to be coming from underneath! A sort of E30 stigmata. Anyone got any idea where this can be coming from?
Not quite sure where you suspect the water is coming in, but the "shark fins" behind the rearmost side glass are held on by three or four push in clips each, which are a notorious source of water entering a touring.
Clips need to be replaced.
Cloggy Saint
oze30
Mine was doing the same. it could be a duff tailgate seal. Changed it all at the same time and its now sorted. however, it could be coming from the rear washer aswell.. (mines leaking there somehow/somewhere)
Yes they would, so it's probably not the fins.datourer wrote:If that was the case then wouldn't the side lockers and speaker housings also get wet? All upper surfaces are dry.
I've realised what you mean by the two rings now (load securing rings).
No, there's no known source of leaks anywhere near there!
Doesn't have a towbar does it, or had one in the past?
Not getting in past the hatch seal, or through rust holes in the hatch and getting down through the lock is it?
KDS
I'd say it's got to be the taillight gaskets. New ones would be a cheap, easy, sensible place to start.
-KDS in Vancouver ('88 325i Touring)
Cloggy Saint
