Rear beam removal?
SPADGE
Post Mon Dec 04, 2006 10:05 am
Hi guys
With the diff already removed is it easier to remove the whole rear beam than just the rear arms? I need the rear arms from a car i am scrapping and am just looking for the quickest least hassle way of going about removing them.
Cheers Spadge..
liam012
Post Mon Dec 04, 2006 10:07 am
as far as i remember easier to undo the the subframe bushes then the two small bolts (usually rusted to hell) which attach the beam to the rear sill. (two small bolts on each sill) should just drop down nice and easy - would prefer that than trying to wiggle away and be a knuckle donor for a few hours at the 4 rusty trailing arm bolts...
TW166Y
Post Mon Dec 04, 2006 10:08 am
Saying goodbye to 4-pot wrongness
Chris-W
Post Mon Dec 04, 2006 10:12 am
I'd have a go at the trailing arm bolts first, personally. They (obviously) have to be removed anyway, and it'll probably work out much quicker than a stubborn beam.
SPADGE
Post Mon Dec 04, 2006 10:23 am
Ok guys cheers for the advice :)
I'll see what is the course of least resistance later and have my trusty WD at the ready winkeye
oze30
Post Mon Dec 04, 2006 11:03 am
spadge,
Undo the 4 bolts on the sills next to the subframe bolts. Undo the big nut. and then the rest should almost fall out ( barring cables and brake lines etc
Cya tonight
SPADGE
Post Mon Dec 04, 2006 11:10 am
oze30 wrote:spadge,
Cya tonight
Cool you can do it tonight then winkeye
TW166Y
Post Mon Dec 04, 2006 12:16 pm
SPADGE wrote:
oze30 wrote:spadge,
Cya tonight
yeh c-mon oz winkeye
oze30
Post Mon Dec 04, 2006 12:25 pm
i'll give it a bash!
TW166Y
Post Mon Dec 04, 2006 12:48 pm
good man 8)
