bad shaking at high speeds
louis2035
i have a 325i sport when i reach about 85mph the steering wheel and the car starts to rattle but once over about 95mph it stops. i have had the tracking sorted and the wheels balanced but still happening. anyone got any ideas of what it could be?
mac325i
if you're running aftermarket alloys - are the spigot rings the correct size/missing
you can get them for under £20 on ebay
HTH
HTH
louis2035
the alloys are the original bbs that came with the car, i will check though as the rings might of been changed or messed with by the previous owner.
jmc330i
Dont think you will have spigot rings with the standard BBS alloys.
Im assuming your tyres are all in good condition?
If the wheels are balanced and tracking done etc, there could be dirt/rust between the mounting faces of the wheel/disc causing the wheel to not mount 100% flat, or even some dirt/rust between the hub and disc but you would probably also have brake issues in that case.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
M5pilot
Control arm bushes?
Very simple visual check will tell you if they are the problem.
If it is those get Eccentric ones fitted (OEM or Powerflex).
Sal
Sal
ajm-e30
possibly warped discs can sometimes cause vibrations
pnd
i had this rattle at a certain speed some years ago and it was the tyres they looked ok but were old.
k
Similar problem years ago, checked all the usual ,changed things that didn't need changing, lots of time wasted etc. Eventually decided to jack the back end up on very substantial jacks/supports and with the aid of mate ran it at "shaky speed" without wheels and observed what was happening, everything was fine so fitted the wheels and hey it shook. It was a duff tyre/wheel that was the cause . Be careful if you do try this as errors could be costly.
wiledw
so good he said it 3 times
Richy325iTouring
bottom ball joint drop link
could be a number or things
Martinaston
Buckled wheel ?
There is NO nucleus.
