any have part no for the jack points on the front of the car?
my dealer cant locate it and i cant find it on realoem
cheers
jack point part nos
E30_Aza
i made mine last night. quite easy mate. dont know the number though dude
ian332isport
Assuming you mean the square bits under the front floor pans then:
a. They are NOT jacking points.
b. They are not available as a separate part from BMW.
Ian.
Ian.
kevin316i
These front square sections don't really serve any purpose except to trap dirt and moisture and generate rust. They should be easy to make up and weld into place. However, I would advise a good coat of wax when the job is painted to help prevent any future rust.
Nelly
- Gumbo
ian332isport
They quite happily sit there minding their own business until some numpty tries to use them as jacking points. That's when the rust problems start. They were only put there so the body could be moved around in the factory, and were never intended to be load bearing.kevin316i wrote:These front square sections don't really serve any purpose except to trap dirt and moisture and generate rust.
Avner
E30_Aza,
an you explain exactly what you did and/or post pictures?
Thanks,
Avner.
Thanks,
Avner.
