hi,
i have a 93 1.6 tourer soon to be a 1.8,
i was wondering how would i go about lowering it? can i just get springs? a mate of mine done his tourer and it dont seem no lower it does seem a stiffer ride tho,
would it be a case of new shocks and springs? any links would be great
Thanks Matt
E30 Tourer
Jamese30
Hi Matt,
The devil is in the detail with this really. Lots of different companies sell springs that they say will lower your car by 35mm, or 40mm, or 60mm. Firstly I would suggest choosing how much you want to lower it by and looking at what is on offer and then asking what experience people have had with those springs, i.e. how much they have actually lowered the car by. My 327i has Terra springs (from German Swedish) which claimed to lower it by 40mm and did around that, my E34 has Sachs Boge springs which do not lower it by the stated 35mm, infact it is closer to 20mm, but the car is still stiffer.
If your shocks are relatively new I wouldn't recommend swapping them for new ones. However if they are old and slightly worn you may as well replace them at the same time, save dismantling the car again later. New shocks will also obviously improve your handling so I personally I would replace them.
Good luck!
Good luck!
James
BMW E30 327i
Mini Cooper S
BMW E30 327i
Mini Cooper S
