callipers from .... (?) other car's brake callipers
ron1999
Post Thu Nov 30, 2006 10:07 pm
Hi all
was wondering - has anyone tried to use VW / Audi / Porche braking pars on his BMW?
my question mainly regards Front callipers / rear callipers and break booster.
looking at the figures like center bore and hub diameter is making sense to me that some of the parts can be used on our bmw's.
has anyone tried is before?
Ron
Jesus325iTouring
Frog freak !
Frog freak !
Post Fri Dec 01, 2006 12:12 am
Got to be honest Ron,in my opinion I wouldn't want to mix and match break parts,best to replace with the correct parts only,the parts were specifically designed to be used together.
As for fitting complete units,i don't know,but i'm sure you could convert other s to fit safely. :D
DaveD
E30Zone Wiki Specialist
Post Fri Dec 01, 2006 11:35 am
the only bits that have been tried is the corrado g60 disc which needs boring out by 1mm to fit but it is 280mm in size so you would need a different calliper ..the one that does work for this is the mazda rx7 calliper with an adaptor..look on e30tech and you will find lots of threads
miniblob
Post Fri Dec 01, 2006 3:35 pm
www.300mm.de
Audi TT discs i think!!!!
Experienced these on Demlots car yesterday - they are awesome!!! By far the best brakes i've felt on an e30!!! Think he said he used TT discs with M5 calipers, but i stand to be corrected!!!!
Think i will be doing this in the new year!!!
327 Touring with bass!!!
DaveD
Post Fri Dec 01, 2006 4:50 pm
only on non standard wheels..ie 16inch plus
look on e30.de
ed325i
Post Fri Dec 01, 2006 5:04 pm
[quote="miniblob"]www.300mm.de
Audi tt discs with e34 540 or e32 740/750 cailpers with adapters.
Will go under 16" or bigger wheels.
Bob_S
Post Fri Dec 01, 2006 7:41 pm
are these adaptors mass produced?
Bollocks to this 24v scrap!
Ant
Retired Team Member
Retired Team Member
Post Fri Dec 01, 2006 8:11 pm
available now from 300mm.de E199 iirc ?
ed325i
Post Sat Dec 02, 2006 5:15 pm
As Ant says from www.300mm.de They a TUV approved.
dazleeds
old skool raver
old skool raver
Post Sat Dec 02, 2006 5:20 pm
miniblob wrote:www.300mm.de
yep these are most deffo on my shopping list
winkeye
www.oldskoolfantasy.co.uk
