On Sunday I will be fitting a new Thermostat and Temp sensor to my 318i M10 engine!! Any hints tips or guidence would be very useful as have never done this before!!!!
Im presuming I will be pissing coolant everywhere and will need plenty of new coolant on standby!!
Also how do I make sure I have not air bubbles in system?!?!?!
Thanks in advance!!
Some instructions needed!!!
RugbySteve
dobbie82
- Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
start off by draining the coolant out, hard winter coming, good enough excuse to change it, and saves a lot of mess!RugbySteve wrote:
oh and i dont know about M10 engines but on an M20 people seem to accidently put the thermostat the wrong way around!
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
stranter
There's no way of draining the coolant on an M10, you need to just unclip a hose and direct it appropriately! Changing the temp sensor, IIRC is simply a matter of unscrew the old one, put in the new one. Thermostat is easy to replace, but the surrounding hoses maybe stuck on to the thermostat, meaning they need gentle persuasion to be removed, or they need replacing. The thermosstat is held in using using jubilee clips. Simply unscrew and prise out. Take a photo beforehand so you remember which way it goes, but I think it can only logically go one way on the M10s...
Stewart
Stewart
