hi guys, got a problem with my 325i sport, brought the car about 2 weeks ago it was runing fine paking it in the garage for a week. at the weekend started it up started fine when i put the clutch down the clutch pedal was all floppy there was no clutch , the clutch pedal does come back up a bit but it is realy floppy. i checked the brake fluid it was low i topped it up and clutch fluid was ok but i still have the problem.
is there a spring or a cable or something that has come of? any help would be appreciated
help needed, clutch floppy
Sounds like your slave cylinder has been leaking the fluid out and its got to the point where none is left so you have no pressure when you press the pedal.
Have a look under the car around the gearbox bell housing area, if the slave is leaking you will probably find fluid around here.
Also check the footwell around the clutch pedal and the engine bay side of the bulkhead incase its the master clyinder that is leaking
gcorky
- Boost Junkie
dobbie82
- Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
and if you do change one, change the other at the same time or you will just have to change it 10 days later anyway!
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
